Completely frustrated trying to deal with adjusting the idle on my 2005 Yamaha F150……
I have been using YDS program to no avail.
It did show four codes….two not recent 13 Pulser coil and 28 shift position switch. Two are recent 29 Intake pressure sensor and 18 Throttle position sensor.
When I run Diagnosis, everything has a Normal result.
When I run Stationary Test, and try to ISC valve opening….I get an Error message stating Engine is running or shifter is in F or R. Program won’t let me go any further.
Needless to say…it is neither running nor in gear.
When running Engine Monitor, the ECU knows the rpm’s are 0 and I can watch the Shift position parameter toggle between on in neutral and off in either forward or reverse.
Throttle valve opening is 0.7 deg.
The Active Test showed Engine speed 1000 rpm, Throttle valve opening 0.7 deg, TPS voltage 0.728V, and ISC valve opening 67%.
So what is up???
I should note that a very interesting finding is the ISC valve gets extremely hot to touch with key on and working with YDS. Engine not running.
Should also note that shifting lever and throttle lever are adjusted per manual.
Anyone have a clue as to what is going on?
Sure would like to get this sorted.
Any and all advice/experience would be greatly appreciated! Thanks.
So what is up???
