Removed lower unit and drive shaft . Busted gear set! Tilted Motor up and engine oil came out of drive case ( a lot ) . What a surprise as i had it tilted up when the lower unit was on and everything was OK .Or so i thought! There was a chance i did not tilt it all the way up then . Question is , is there a seal on the driveshaft that keeps engine oil somewhere in the block or does the driveshaft case have a pocket that will hold engine oil from an oil change and scare the crap out of you at a later date. I see what seems like a seal ( #21) in the parts view but there is no listing for it . Goes # 20 to #22 . Skips over # 21.
Hope you guys are having a safe 4th of July
Thanks in advance . Norm in Arkansas
