2006 Honda BF225 Beeps warning
HenryTayninh
Hi Captains,
Last weekend I took the boat out and it beeping after start up. After a while it still beeps then I turned it off, then start back up it gone.
I drove around it was fine, but occasionally it beeps again at idle. After searching around and most people say it most likely the O2 sensor.
Any of you have this similar issue? Any recommendation where do you start?
Engine: BAGJ-140067x
560hrs, I have been own it almost a year, previous owner said he serviced at dealer and maintenance are up to date (but no receipts whatsoever).
I did replace the fuel filter, water separator thing, thermostats, and sparkplugs.
I have the impeller, but not have time to replace yet, so far the tail tail water coming out strong though.
(If it's an o2 sensor issue, I want to replace it myself too).
Henry
Is the alarm constant, long beeps (once per second) or short beeps (2 per second?)
If you have the four-light key switch, see the first attachment to determine where to look.
Pull fault codes. The second attachment tells you how. The third attachment tells you what the fault codes mean. Come back and tell us what you find.
  • BF 225 Alarms.pdf
  • Procedure for Getting Fault Codes.pdf
  • MIL Fault Codes Scanned.pdf
Thank you so much chawk_man.
I have the four-light key switch. (post back here for my reference later)
red = coolant temperature;
green = oil pressure;
red = alternator output;
red = malfunction indicator light (MIL.) or check engine light.
I remember the "check engine" (MIL) light was on, but since I have to move the boat out of the dock for others to use the dock, I didn't look long enough to see if the light stay on or blinking.
For the beeps, it was like 2 seconds intervals.
I will take her out again then record the issue to see exactly what it was then post back here.
Thanks again and Happy Easter!
I took the boat out this afternoon and it doesn’t beep anymore. Spent few hours on the water with idle speed and a few stop and go, nothing happened.
If it happens again I will post back.
Thanks all.
I took it out today and it beeps again after running for a while then stop. It didn’t beeps while driving but does after stop.
The beeps is 2 second long and the check engine light is on.
I turned it off then start again, no beeps, it’s fine for the rest of the trip.
Pull codes as I suggested previously. Best procedure is to pull and record the current codes, then clear the codes, then run the engine until it alarms again, and pull the new code(s).
FYI - codes are stored in and remain in the EPROM until they are cleared.
Want to post back for record.
It doesn't beep any more after replacing the water temperature sensors, use Non Ethanol fuel and replaced the anti siphon valve on the fuel line (right above the fuel tank). Instead of replacing the valve, I used a drill to bore the hole a little bigger to take the spring and stainless steel balls out (no more valve), it runs better and solved my engine stall fuel starving issue too.
FYI: Normally, there is also an anti-siphoning valve built into the primer bulb. Sometimes those also fail and cause running problems.
Correct. I replaced the primer bulb w the after market one on Amazon, but my friend who is a mechanic said throw that away as it often failed and bought the one from Yamaha made in Japan ( around $45 6AW-24360-02-00 PRIMER PUMP ASSY (Yamaha) ) and I did. It works great.
