2006 Honda Bf225 rough/sputter/misfire at idle
JayfromNH
Hey all, have been reading this forum for a while now. I have an 06 225 and have been having idle issues for a while now. Sometimes it will idle smoothly, but randomly will start shaking and sputter. Almost sounds like it’s misfiring. Similar noise to how a car with a big cam sounds, loping. It runs like a top at high rpm, no issues yet.
Things I have done: replaced HP, LP filters, and fuel water separator in boat. Cleaned IAC valve. Cleaned MAP and IAT sensors. Checked plugs. Pump primer bulb when it acts up (no change). Drained the VST while pumping bulb. New thermostats and water pump. Nothing has really solved this. No alarms ever.
Seems like a needle in a haystack. Could be valve adjustment, or VST HP fuel screen, or bad coil, or bad fuel line or bad O2 sensor. I’d rather troubleshoot the issue one by one instead of just throwing parts at it.
What would you check next? Does everyone’s run crappy at idle? It’s not that big of a deal as it doesn’t stall, but I don’t want to wait until it starts giving me real issues to figure this out. Thanks in advance!
Hi,
I don't work on these but am thinking I might try removing and clearing the throttle body.
If the throttle blade or air passage gets dirty, it could cause it to stop at various positions when at idle and that could cause the TPS counts (resistance) to change and be inconsistent.
Use throttle body spray cleaner ONLY and use caution about handling it because they are no longer available new. No scrubbing with anything more coarse than a soft toothbrush. NO OOPSY DROPPSY! Use great care and accuracy when handling and, plugging in the electrical connectors.
While there, check out the flame trap screen and clean if needed. Item 6 in the link
Also in that area are the tubes for the crankcase breather system. Items 28, 29, 30 in link below
Make sure they're all properly connected and secure with no holes or cracks
Good luck.
I totally agree with JGMO on that advice.
I think that if the screen on the bottom of the HP pump holder was clogged, you would have problems at higher RPM's.
A bad plug, coil or HO2 sensor you give you a code 1. Maybe pull codes. 2 documents attached - the proper way to pull codes, and what the codes mean.
Another possibility is that the intake IAB (intake air bypass) is intermittently sticking open. To test that, see the third attached document I wrote up several years ago - the first 5 paragraphs.
One final (a bit off the wall) thing comes to mind is that maybe your LP fuel pump is malfunctioning.
  • Procedure for Getting Fault Codes.pdf
  • MIL Fault Codes Scanned.pdf
  • Honda 225 Intake Air Bypass.pdf
If I had an active fault, I was under the impression the buzzer would sound each time it’s started? (Separate from initial ‘key is on’ buzzer) Other issue I need to fix to pull codes is that ALL of my lights including the MIL have burnt bulbs… which I just found the right parts diagram for yesterday. On their way.
Funny enough, I had seen your post already on IAB, so I checked mine and luckily she moves well! Lubed it up while I was in there!
JGMO, great advice. Actually, before the season I had taken off the entire air box and that flame screen was mostly fine, cleaned it anyways. BUT I did notice my throttle body was filthy and gave it a good wipe, but didn’t take it off for a full cleaning. I’ll give that a shot next.
When I went to clean the IAC, the screen was completely plugged with junk. So much so, that it was sucked inward toward the throttle body from how blocked up it was. Thought that was going to be the smoking gun fix!! Cleaned that very well and the valve/ solenoid seems to be functioning per multimeter test.
Also, per the service manual for adjusting idle, i unplugged it, alarm came on, but the engine died almost right away (manual says rpm should just drop lower, not die completely). And when I give it a bit of throttle slowly, I can still hear secondary air being pulled through that IAC. When’s that solenoid supposed to snap shut?
I don't know specifically but I believe the ECM should be closing the IAC as soon as it sees the TPS counts rise from base idle. The IAC can be damaged if manipulated manually. Hopefully that hasn't happened.
From what you say about the IAC being so dirty, it.sounds to me like there could be some gunk/debris floating around inside the bypass passage or stuck to the tip of the idle adjusting screw. If that passage gets restricted, even a little, it will cause the idle to go low.
Conversely, an air leak from a damaged passage will cause the idle to be too high.
Bottoming out the adjustment screw can deform the bypass seat and/or the tip of the screw. That could result in an erratic idle that can't be properly adjusted.
This throttle body may tolerate small, gentle, manual movements of the throttle valve/plate but they are easily damaged from being handled like that. If the blade is opened and accidentally slips and snaps closed, damage can occur. Even wiping/cleaning too aggressively with a soft cloth is advised against so be very careful with it. Finding a replacement might be difficult and expensive.
Good advice, I’ll give the throttle body a good cleaning and check those things out. Sounds like I gotta be more gentle with it too…
Jay, I am having the same problem. My engine stalls right after start. If I rev my engine up, then it will run fine. I cleaned the IAT screen and it "resolved" the stalling issue. Now it idles rough and stalls once a while. It runs fine once I get it to run. I was going to continue my fishing season, but my wife wants me to get my boat "fixed". Finally I got my trailer fixed and ready to pull my boat out. I am going to try what Jay have done and see if that will resolve the rough idling issue. Wish me luck.
I’ll keep this post updated as I troubleshoot things throughout this next week.
Also fighting a sluggish starting issue.. very odd. Brand new batteries, newer starter within the last few years. Happens at random haven’t noticed a pattern yet, but occasionally when I go to start it, it will barely turnover for the first second or so then while holding the key there it will get moving but still very slowly. Did a voltage drop test on the ground side, from starter ground to battery ground to check if the cable or connections have some resistance, and saw 2V drop which is way WAY higher than it should be, but also seemingly impossible for the starter to even turn at that low of a voltage. But the odd thing to me was I saw the same exact reading when testing the positive side. My battery switch is super super stiff to turn so I’m gonna replace that anyways.. hopefully maybe it’s just that.
I've had a similar issue with my 07 bf225. Sprayed electrical contact fluid in every place I could get too, then with battery disconnected, turned the selector switch it's various positions at least a dozen times. Problem solved. Probably just dirty contacts.
So did some work this past week and weekend. Starting issue is solved. Battery switch was junk, and cable ends going to it were also junk. Replaced the terminals with new, new switch, starts right up like it should. End of this season I’m going to replace the entire bonded cable that comes with these motors because it’s also looking a little junky, lots of black oxidation that is super hard to get off, and keep off, as well as just overall dry aged condition of it. I cut off probably about 2 feet total of cable trying to find decent shiny copper but to no success, it must have wicked water all the up it over the years.
For the idle issue, I took off and cleaned the throttle body carefully and as best as I could. Still crappy idle, maybe a little better, but also maybe placebo. The TPS is permanently affixed it seems so I couldn’t clean that and didn’t have an extra set off hands to test it with a meter at all different positions. Also took a quick look at those vacuum lines and didn’t notice any obvious cracking or loose hoses, maybe I’ll pull them off and inspect better next time.
I think I can live with it for now, but I can only imagine it’s going to get worse and eventually ruin my day on the water. Would love to keep trying new ideas that anyone has for check ups that don’t involve tearing everything apart mid-season? Saving that for end of season. Thanks again!!
Glad you got it under control for time being. Yes, definitely change out those cables.
As for the idle problem, have you checked fuel pressure it idle with regulator vacuum pinched closed. Should read 41 - 48 psi.
I have not checked it, but that seems like the next easiest thing to check. If fuel pressure reads stable and as expected, should mean everything from there back is functioning in the fuel line up (in theory). I’m a little bit stumped on the service manual guidelines for checking/adjusting idle. As stated earlier, when I unplug the IAC it immediately dies… which makes sense when looking as the air passages of the IAC/ throttle body. No air flow can get to the manifold since throttle plate is closed and the IAC is subsequently closed by unplugging it… weird. Wonder if that procedure is just written incorrectly, or if it’s indicative of an issue with the IAC…
Just an update: still haven’t gotten time to dig into the idle issue, just been enjoying it for the summer. I found a YouTube video (not mine) but it very exactly represents what my motor does. Runs fine, then stutters and shakes like that, then back to normal. (not quite as bad as the really bad stuttering that in the video, but close). The creator of the video never confirmed what the fix was, but a lot of comments saying O2 sensor. Video url copy pasted below.
Let me know your thoughts on that!
