ProTurbo
2007 Mercury Verado 150 (supercharge) (1B546713) Will only start full throttle and will hardly not idle at all and if it does it rough and stall. When she starts at full idle and let her run at 1/2 throttle, we can see a lot of fuel spitting out of the exhaust, all over my garage door (BLACK) and not running to well.
Plugs are black, replace plugs, water filter and both rubber hose between the valve boost control it was crack, so we thought it was getting too much air. still the same PROBLEM. Check the boot where the map senser is ok, tested the senser to the ecm ok. check is I have fire to plugs ok, check fuel pressure ok at 47 PSI, check compression of pistons around 110 PSI each. Thank you for your help
PS: also check for bad gas and water in the talk, ok
