JerryinTex
I have a Tohatsu 8hp 2014, that my brother put fuel in crankcase. (Yes, I know, stupid) I drained that and put oil in it, then took down the carb, soaked it in cleaner, replaced the bowl gasket, reassembled it, hooked up the fuel lines. When I squeeze the bulb, no gas is coming out. It is sealed. But the bulb does not get hard, and the motor will start but only run a few seconds and only at full choke. What do I need to do to get this engine running again? (spark plugs are new and I get a good stream) It has to be fuel, I would think, but I can't figure out where!
