Scottybluewater
Good Afternoon - Prior to starting this adventure I contacted Mercury Marine in order to get the correct part number for the shift cable kit. I was told that there was a new part number so I bought it.
This cable is not the same as the one .- The brass ftg at the shift plate is larger/longer, therefore it does not rout the same. (not close)The inner wire cables are the same length. I was not able to measure the old housing as I destroyed it.
My question is - do i try and make this shift cable fit - new route/path - all proper cable adjustments - or do l need to try and find a new old one.
As always I appreciate any help
