3208TA Pat
1st post to this forum! Need Help.
Tried starting port engine this morn and not even a sound when I pushed start button. I was able to jump start at the solenoid though and engine ran fine. I then replaced solenoid. No luck. Then I tried starting from flybridge. Same deal - no crank action whatsoever. Stb. engine starts as usual. Both start off same battery. Could this be a starter relay issue? If so is there a test to perform. If not what else should I check?
Thanks.
Thanks.
