Bohemian Boat owner
after replacing the impeller.....i've been having a heck of a time getting the shift linkage in this Gale to work correctly. I've read numerous times about placing the groove in the center of hole in the brass linkage....my question is....what is the correct order of replacement: Bolt the lower unit entirely back on and then try and get to the bolt to tighten around upper shift linkage? and is the shifter in neutral? I'm also doing this without starting the motor......is this a problem also??
thanks in advance for the help!!
