Bracker
I have decided to go with a 383 with Vortec (062 casting) heads, 22cc volume reverse dome hyper pistons, 5.7” rods, Comp XM264HR camshaft and Scat forged crankshaft. As currently configured it should have a SCR of 9.27:1 and a DCR of 7.62:1. Someone ran the specs through DynoSim6 for me and the torque numbers were exactly what I was looking for.
However, I’m still trying to settle on a manifold/carb combo. It will have a full FWC kit, but as you guys know, Dennis Moore recommends using a cast iron manifold with cast iron heads (besides the corrosion factor) due to the expansion rate differential between iron and aluminum and how that affects the head gasket. What are your opinions on this matter? If I do go with the cast iron manifold, I believe all that are Vortec compatible are configured for a spread bore. I know there are square bore adapters but I’m ocd and I’ve read several places that this isn’t ideal.
The forum’s thoughts and advice will be appreciated. Thanks!
