Last fall I was gifted an older boat from my parents that hadn't been used for a number of years, I don't know how many but some where 6-10 years I would guess.
Its a Regal bowrider with a 4.3L Mercruiser I/O
Although it was stored indoors it has has some corrosion issues with wiring and some of the mechanisms.
I got it running ok, but sitting in the shop with it running on the ears, it immediately stalls when you put it into gear, forward or reverse. It's idling at 850-900 RPM
On further inspection I find that the little "interrupter" microswitch which is meant to momentarily stall the engine so it goes in and out of gear is staying stuck in the closed position and therefore killing the motor.
