darlington_john
Ok, carryover from a previous thread. 2007 4.3 MPI 220hp that ran fine last year prior to winterizing. Started it this year and it ran fo 5 minutes and then cut out. Would restart but only a few times at rough idle and then die. I assumed it was either not getting fuel or there was water in fuel. So far I have done this to rule out bad fuel - ran the tank on an auxilliary tank where I tied it in to the system just before the fuel filter. Ran it for 0 - 15 minutes (on muffs) and it ran great.
Drained the main tank dry pumping out from the gas line which ties into the fuel filter. Reinstalled the gas line, put in 10 gallons of 89 mid-grade and started the engine again. It ran for 5 minutes (on muffs) and then started cutting out like it did before. Now I'm thinking that it is not getting any fuel from the main tank to the motor. Started lifting the floor to have a look at the tank - this boat has 50 hours on it. Looks clean.
So, it ran last year, now it doesn't on the main tank. Anti-siphon valve stuck???? I'm at a loss right now as it has to be the line from the tank to the filter. I can't see how it runs great on the auxilliary tank.
