Austintatious
Where is the oil pressure switch on a 1992 454XL?
The other day I was running around 3K rpm when the RPM's started to slowly drop and the engine died. I was able to restart it but it wouldn't rev past 1500 rpm under load until it would slowly climb up to around 3500 rpm at full throttle.
I ran some cleaner thru the carb, took it out and while the RPM's would slowly rise and sometimes fall there is a definite miss. It acts like it's starving for fuel.
Anyway, I've got a new fuel filter coming in but I wanted to also check the oil pressure switch that controls the fuel pump.
Where is it mounted?
