5.7 gxi fuel pressure issues
mww4040
gotta 2002 5.7 gxi, low pressure fuel pump reads zero. high pressure test at rail reads between 85-90. Engine starts fine runs fine on the water . Sputters and wants to die at higher RPMs.
the engine needs to be under load and at different RPM (idle, 2000, 3000, and WOT) to check the fuel pressure...
The rail pressure seems high to me (assuming the reading was using the PSI scale)...
Being a 2002 I'll assume your GXi is above the B series, so at least C to G, serial number will verify
If correct your fuel pressure should read, Low side 8 +/- 4 psi, High 50-60 psi from idle to WOT
Seeing your at 85-90 psi, your Fuel pressure Regulator took a dump, or the return line back to the filter is clogged solid
Yes my guage is PSI , but its a cheap gauge . Not sure if that would be an issue ? Engine model is 5.7 gxi c. I removed the pressure regulator and inspected, found it to very lightly dirty, didn't see any of the paint chips everyone mentioned. Cleaned and reinstalled, not sure how to go about finding and inspecting the return fuel line ? Should I just replace the fuel regulator at the rail ?
Pressure side, you need to know when the Reg opens
Ok, finally installed a new oem fuel pressure regulator. Now the pressure at the rail is 49 psi, still reading zero at the low side. Boat fires right up as it did before. my tachometer has not worked for years so i did raise the Rpms up a little still zero reading on low side. would this thing still run and start smoothly if the low side pump is dead ? I unplugged the high side and turned key on and can hear the low pump making some kinda noise.
I have nothing
Don't see how zero psi will work other than the HP pump is able to suck fuel thru the LP pump, at least your not seeing a vacuum on the low side
Check the fitting to make sure the valve gets depressed...every once in a while I've seen it where things functioned but the gague showed a zero...and it was an interface issue.
And yes, you really need to have the boat out on the water to get a meaningful assessment...until the engine is loaded as designed, the fuel requirements are minimal...
Ok, finally getting back to everyone about my solution to my problems. Replaced the fuel regulator valve and the fuel cell assembly. Just had the boat out on shasta for a week and she runs great. On top of that she seems to be doing better on fuel consumption, ran the whole week on one tank of gas/ 41 gallon tank. Im a happy man, thank you to everyone's input.
