Trim worked in the yard. Stored the boat this winter with the lower unit in the down position. Moved unit to transport position. Lowered again to check all fluids then moved to transport. All worked fine. Then put it in the water and nothing. No noise, nothing. I checked the fuse under-dash and fuse on trim motor, both are fine. Jumped the motor directly to battery. Motor made noise but the unit didn't move, (maybe it won't). Could the switch be bad? Any help would be great. Thanks
