cjbrill715
I’m re-sealing a lower unit off a 1984 50 hp evinrude. Myquestion is, the three bolts that hold the bearing carrier in place (that havethe little o-rings on them) what kind of torque are you putting on these? I’mafraid of tightening them too much and squashing the o-rings out. Also, while I’mat it, do you guys use gasket sealing compound on the bearing carrier on themain o-ring that seals it to the walls of the gearcase casting? Or just greaseit?....Lastly, do you guys put grease in between the stacked shaft seals (oilretainer seals) that are on the prop shaft, and drive shaft? I just oiled thelips, and didn’t put grease in between them, was wondering if that is goodenough?
