50hp Merc float level
lanky
"Hi guys,
2001 50HP Merc out
"Hi guys,
2001 50HP Merc outboard – starts fine initially, but really battles to start after stopping once I get the my fishing spots. I am pretty sure that it is float level problems.
Can you please help with the spec’s to set the float levels?
Carb type:WME-2XK, top and bottom carbs and WME-1XK – center carb.
Many thanks. Lanky."
"When you hold the carb body u
"When you hold the carb body upside down, the float should be roughly parallel to the carb body."
The float levels are just fine
The float levels are just fine.....I'm not sure where to go now. This motor is 7 years old but only done about 80 hours. It has always battled to start once it is warm. Lots of smoke etc once it eventually takes - almost like it is choked - could maybe not getting enought air.
I would appreciate any ideas.
Thanks. Lanky.
