60FETO 2 stroke bogging down under load
Fisherolf
G’day All,
Hoping someone can assist. My Yamaha 60FETO will starts easily & on earmuffs will rev out to over 6k but once in the water bogs down @ 2.5 - 3K & stuggles to get on the plain.
Chasing the problem i have replaced all fuel lines, fuel filter, fuel pump, checked main jets on all 3 carburettors (all 3 carbies are new), paid to have the throttle linkages & timing adjusted professionally, replaced all coil packs & spark plugs, replaced the head gasket, checked that the exhaust is not constricted, checked cylinder compressions (all around 110psi) & ensured that the gearbox operation is not restricted.
Biggest problem is that as the engine runs fine on the driveway, testing involves a 1 hour drive to launch the boat - only to be disappointing 5 times & counting.
Ant suggestions would be greatly appreciated.
Rolf
On muffs that thing needs almost nothing. No load, no exhaust backpressure, tiny fuel demand. So six thousand on the hose only tells you the ignition and the fuel system can keep up with a free running engine. In the water they cannot. That points at something that only shows up loaded.
First test in the water, and it is free. When it starts to lay down at twenty five hundred, reach back and pump the primer bulb hard. If it picks up and pulls through, you are short on fuel volume. If nothing changes, it is spark or it is air.
If the bulb does nothing, get an adjustable spark tester and open it to seven sixteenths of an inch. Check each lead under load, not on the trailer. A weak coil or a tired stator will jump a small gap all day and quit on a wide one.
While you are there, look at the plug boots at night with the cowl off. Any blue tracking down a boot or across the block is your miss. Those caps crack and only bite under compression.
The stator is worth a hot test. Peak voltage on the charge coil cold, then again right after it acts up. Heat soak failures on those CDIs look exactly like your story and never show up on a cold driveway.
New carbs means the intake joints were disturbed. At idle spray carb cleaner around the carb bases and the manifold gaskets. Any change in rpm is an air leak, and a lean leak will bog it right where you describe. Check the main jet numbers against your serial too. A set off a fifty or a seventy runs wrong in the transition and the seller will not tell you.
Reeds. A chipped petal is fine in neutral and falls on its face loaded. Pull the intake and hold a light behind them.
Two more things. What pitch is stamped on the prop, and what rpm does it actually make at wide open in the water. And is the floor foam wet. A waterlogged hull bogs a healthy motor and no amount of tuning fixes it.
Hundred and ten on all three is a bit low but even, so I would not chase that yet. What gauge, throttle open, warm?
What does the bulb do, and does pulling one plug lead at a time in the water change anything? thanks
G’day Miles2000 many thanks for your quick response !
Just a little more info - the motor was running fine earlier this year but unfortunately I snapped the throttle cable. Not an issue I thought, purchased & installed a new cable & since then I’ve had the “bogging” issue. The fact that the motor was screaming along earlier in the year would suggest to me that the carbie jet sizes & prop pitch are ok.
Thinking that I’d somehow messed up the linkage adjustments while fitting the new cable, I took the boat to my local Yamaha Outboard stealer who adjusted the throttle, checked the timing & undertook a full service, which included new plugs. Unfortunately once on the water (& $1,000 poorer) the problem persisted.
I then thought I found the “smoking gun” when I discovered that my fuel pump was leaking (split in the diaphram) but a new fuel pump also failed to resolve the problem (actually replaced the new fuel pump as well, just to sure). Motor also appears to be getting enough fuel, as squeezing the primer bulb while motor is under load fails has no impact.
I then turned my attention to the electrics, replacing all 3 coil packs; still no go.
What I haven't done yet is replace the Stator (as per one of your suggestions), so perhaps that’s my next port of call. Actually - first off I’ll follow your suggestion of checking for air leaks (by spraying carbie cleaner around the base of the carbies) - that’s a freebie that won’t incur further grief from “the minister of was & finance” - she’s starting to get pissed at the cost of solving this issue !
Once again, many thanks for responding.
At the point the motor starts to bog I would have someone spritz a bit of gasoline into the air intake system to see if the motor then picks and runs, or if the problem remains the same
Hi Boscoe & thanks for your input,
I’ll follow your advice (next time I get a chance to take the boat out) but wondering how to interpret the result ? I assume that the motor will splutter if over fuelled but not sure what “no change” would indicate ?
