MattZimmerman
Symptoms:
oil in the coolant and slowly loosing coolant, otherwise engine performing normally
We thought to check the oil cooler, pulled it, took it to a shop, they opened it, did their thing and sent it back without a report of a problem. Our symptoms persist.
Cruising these forums there is clearly a lot of knowledge here, so what I'm looking for is ideas on things for us to check, in order of likelyhood. Our maybe even check some not as likely possibilities before we get into spending the big money, as oil in the coolant sounds like there could be a serious issue. I'm not exactly sure what that issue is. Educate me if you are inclined, please and thank you.
