Tattoomike
So I got this matter several years ago as a Father's Day present and it ran awesome until last year the next time I took it out it just did not want to rev out idled find mid-range seemed okay but it would never go about over half throttle
This year I went through it rebuilt the carburetor very well I might add I also replaced all fuel lines and fuel pump new fuel hose and primer and tank and filters and all that
I check the spark and the thing will throw a loud crackling spark over half inch away from the block from the plug and the wires are in good condition the coils I'll be old have plenty of heat coming from them quite spectacular spark I might add and also my linkage cam to the throttle seems to be pretty close as far as adjustment.
But even though it idles fine and gets up to about maybe half throttle slightly less and I've checked the butterfly opens completely 100% but it just seems like it's running really rich and oddly enough it acted exactly the same last year when the problem started but the carburetor was completely clogged up with rust and varnish and the fuel pump didn't work full of rust fuel lines were cracked and all that so I figured doing all the stuff that I did had to fix it but it did not it didn't make a difference at all
So considering I have a new carburetor and new fuel pump and delivery system that is checked and working all well I can only wonder what's causing what seems like a rich condition because when I pulled the spark plugs they were soaking wet with gasoline
I'm getting very frustrated with this motor because I've had it for 4 years and I've had the boat about 15 years and this is like the sixth time it's ever been on the water because I could never afford a motor and I went and wasted all this money apparently for nothing and it's such a hard thing to load even though it's a 12 foot flat bottom I don't have a trailer so I have to pick it up and drag it into the back of a minivan and then pick up the motor and carry it to the boat and put it on and blah blah blah
What would cause this low output at Full Throttle and wet plugs?
By the way this is my first post here
