I have the same problem with a 87 Johnson 110.
I was*busy this summer and hadn't had a chance to run the motor this season, but I managed to get some time over the weekend to fire it up using the muffs.
It started and ran great, I cycled through forward and reverse without any problems.
I let it idle for about 10mins, then shut it down.
When I looked at the motor the next day, I noticed a significant amount of black greasy oil contained within the prop hub. Oil had also leaked from between the propeller and the lower unit, flowing down to the bottom of the lower unit and dripping to the ground, and forming a puddle of 2-3oz.
The oil was black and heavy, and had a gasoline/burnt smell to it.
After reading several posts describing similar oil leaks and the smells/colors of the oil that is leaking, I*believe it to be unburnt engine oil from the idling, but I do want to be sure that it is not the shaft seal.
Can anyone comment on this?
I have not been able to remove the upper gearcase oil fill, as it is very tight. So I have not checked the level of lube yet, but I know when I put the lube*in it was a nice dark-honey color-- not black.
Does anyone know of any tricks to getting this plug loosenned?
Also, if/when I do get the plug out, can it be replaced with a plug that has a nut/torx/socket type head? I can't believe OMC used a slotted head on this bolt.
Thanks,
Matt.
