1990 Johnson 8hp J8RESR
here is the more complete backstory in one of my previous posts: http://www.marineengine.com/boat-fo...0-8hp-Johnson-idles-but-no-wide-open-throttle
I have rebuilt this carb at least 3 times and also had a couple of guys that are pretty solid with outboards rebuild it once. Stripped it down completely, cleaned all of the orifices, replaced everything in the rebuild kit including float every time. Each time, it starts out running pretty good, but it doesn't last. I can't get WOT, then it won't idle well, and then it's just a mess of flooding (gas pouring out the carb throat). I would certainly seem to lean toward float stuck or needle valve not closing, right? What would cause the same thing to keep happening, though?
The thing I haven't replaced is the idle mixture screw. Should that need to be replaced?
Other notes of interest:
- i've replaced the coils, wires, plugs, fuel pump, hoses, impeller. Done a compression test. added an inline fuel filter. Fresh gas mix a bunch of times.
- the tank I have is a regular 6 gal outboard tank, but I don't think it's vented (not sure if it's supposed to be). The old tank I had would never swell like this one does in the heat of the day. Is that supposed to happen? I have to open the cap to release the pressure. Could that be causing too much pressure in the system and blowing out the little valves and such?
- the inline fuel filter is clear. When the system is primed, the filter is never "full." Is it supposed to fill up completely to flow fuel correctly or not?
Do I bother rebuilding this carb again? Something I should do or try differently? Is it possible that I just need to replace the carb entirely? Problems that I can't address? Anyone have one they'd part with or a good 3rd party source?
Thanks all for any guidance on this before I kick it off the back of the boat and be done with it once and for all.
