Snapper Fisho
Hello, I have an Evinrude 9.5hp that runs well without hood on but dies with the hood and noticed a small fuel/oil mixture leak from the bottom on the inner exhaut mainfold plate that attaches to the port side of the crankcase. I pulled it apart and it wasn't obvious where along that gasket when inspecting. I have pics to show the leak along the bottom. I have started to clean the insides and remove the old gasket.
Has anyone seen a leak from there before on these turtle motors?
I also inspected the lower oval exhaust seal and it looks quite good but has a couple of pressed in curves on both sides, I assume from the shell. This part is no longer available here in Australia and neither is the inner exhaust plate gasket part no: 309709. The gasket is available on this site though.
Is there a gasket maker I could use instead? A local marine place said to use Hylomar Blue.
Any thoughts from the very experienced here please? Thanks
