I have posted threads related to this issue on other forums and gotten some good advice, but have not been able to track down this issue yet. I need a fresh set of eyes on it. Frankly, I'm at the end of my rope with this thing. I'm going to write a novella here, so sorry for the length, but hoping being thorough will help.
1990 Johnson 8hp J8RESR on a 12' Jon Boat
backstory:
over a year ago, the motor was running great at all speeds. One day, we're out flying around in the Jon Boat with it wide open and all of a sudden, it sputters pretty hard and stumbles and will no longer hit wide open throttle in gear. It was running fine and then it wasn't. It wasn't a gradual deterioration. It would idle and run in low/mid speed range, but with the throttle wide open, it would stumble and shake a bit. In neutral, it'll throttle up perfectly, but not under load. To me, it felt like I lost spark on one of the cylinders. I messed with the motor for some time back then, trying to get it right, but never could. And then it sat. Fast forward a year (this summer), and it was time to "get that dang boat running again," so I attacked it.
Current Status: same issue - idles but no WOT. Bad stumble/bogging
I started by rebuilding the carb and replacing the fuel pump. Checked for spark, and compression. All seemed good. I put it back together and had the same issue. I ended up giving it to a buddy at work that is fairly proficient with outboards. He and his buddy tore it apart again. Rebuilt the carb, changed the impeller and some odds and ends cleanup. They got it running and idling nicely and they THOUGHT running right. What might be an important note here: the only way it would idle is with the mixture screw turned out like 7-8 turns. He thought that was odd because everything calls for 1.5-3 turns.
I took it back, hung it on the transom and out I went, or so I planned. I couldn't get the stupid thing to turn over and idle and it did just hours before that. I gave it back to them. He said they took that carb apart again and thinks the float got stuck. Gave it back to me, and out I went. It idled nicely. But STILL no WOT.
So, back to the bench. I pulled the carb AGAIN. Thought maybe the float needed setting or the needle was sticking. I noticed that the nozzle well (plastic riser in the center of the float) would slide down out of place when the carb was hanging. It actually seemed to interfere with the float moving, like it rubbed on it. Thought that might be it. I re-secured it in place, cleaned everything up again, put it all back together. This time, I set the idle speed and mixture screws to spec. The cam roller right at the mark on the flywheel and the mixture screw to 2 turns out. Got it to idle nicely at these settings. First time, so i thought maybe I had it.
At first, it did the same thing, but then...fired it back up and went for another run and at first it started acting the same way but after a minute it sort of got itself together and throttled up perfectly. I was able to run it at wide open throttle for a few minutes! When I backed off the throttle slowly it stalled. Then, I couldn't get it to idle at all without manually feathering the choke off and on. I ended up backing the mixture screw out to 7+ and turning the idle speed screw up a bit to get it to idle again.
Pulled the flywheel and the key is fine. Put it back together. No change.
I decided to turn my attention to spark. I decided to just replace rather than test/guess. New plugs, wires, and coils. No change. I ran it around my Lake a bunch and couldn't get it wide open just like before. Unlike last time when it finally did kick itself over it didn't do that this time totally. However it almost did and I might have a telltale indicator. I could feel it start to throttle up strongly but at the same time I could hear a distinct clicking. To me it almost sounded like what you hear when a spark plug arcs. The click definitely coincided with a throttle change. Again, I thought maybe I had it figured out. Now just had to find the arc. I ran it at night thinking I'd see it, but of course, now it won't do it. I decided to pull plug wires and see what I felt. I pulled the top plug wire and started it. It idled noticeably worse. I put that one back and pulled the bottom plug wire and started it. I immediately heard arcing. The retaining clip that I believe attaches the ground leads on the bottom coil we're arcing. I think that not having the plug wire attached forced the spark to try to find an exit. I thought I may have figured it out - again! I adjusted that retainer to be farther from the spot it was arcing, reattached the plug wire and fired it up. No change.
So, that's kind of where I'm at. Some thoughts:
- While it was bogging (WOT), I squirted some fuel mist into the carb throat and it got worse. To me that indicates it's already getting too much fuel. Yes? Would being WAY to rich cause this behavior?
- could it be something else with the ignition system based on these symptoms? Power pack, charge coil, rectifier, etc
- I read a post somewhere that a guy had similar issues and it was plugged up exhaust system. Is that worth looking into?
Are there some other tests I can do to help ELIMINATE possible culprits? I'd love to be able to narrow it down to definitely ignition, or fuel, or mechanical, or whatever.
It goes without saying, I really appreciate the time to read through this mess and any help offered! I'm buying a round for the group that gets this thing right!
backstory:
