fishhawk90
Hey guys I was just wondering if someone can tell me what’s the purpous of these ports. It only lets air out & not in. Two of them under the top carb connects to a tee that goes to a port on the side of crankcase that feeds cylinder 3. One goes higher up to cylinder 1 closer to where the 3 intake holes r in the cylinder .
As for the port side 1 goes to the exactly the same location to cylinder 2 as cylinder 1. & cylinder 4 has none going to it except the 1/4 vlave that goes to the vro pump which draws vac when the piston goes up.
are these valves to release pressure against the reeds & redirect it back into the cylinders? & if that’s the case why won’t cylinder 4 have one to release its pressure as well?
