I bought a project boat a couple weeks ago that Ive been trying to get running. It is a 1989 charger 195t with a 1995 evinrude 200 horsepower outboard. So far Ive replaced the spark plugs, replaced the fuel pump with a non-VRO pump and mix the gas 50:1, and replaced the carburetors with a used set (originals were warped bad). I have a clymer manual for the engine and followed every step of the link and sync process but I am having a spark timing issue now. At idle in the water in neutral the spark timing can be adjusted all the way back and still sparks number 1 at about 12 degrees. My manual says specs are 0-4 idling in gear but either way I move the timer base linkage it will not get that low. I even pulled the linkage off the timerbase and moved it by hand both ways while running and its way off. It runs very rough and stalls constantly because of this, i havent even had the boat off the trailer yet.
To me it sounds like the timer base has failed on me but I followed every step in my clymer manual to check the ignition system and everything is within specs, the timer base is a pricey parts to take a guess on. Are these typical symptoms of a failed timerbase or should are there any more tests I can do to diagnose it better?
