Oldsaltydog
Late spring, I replaced the water pump, removed cylinder heads and exhaust cover and cleaned out all sediment (there wasn't much gunk in there), replaced poppett valve and checked thermostats. They both opened and closed at the correct temperature. Today, any time I got close to WOT, it would sound the overheat alarm. After this happened several times, I found that if I kept it at or below 4,000 RPM's, it would not have any problems. Cranks right up and runs great. I'm confident that it's not a lean condition. It runs perfectly at WOT, which is about 5200 RPM's. When the alarm goes off, it does appear to be actually overheating, but the tell tale stream is quite cool. If I back it down to idle and let it run just a couple of minutes, the alarm goes away and it's fine for a good 10 minutes of WOT before it goes off again.
Any ideas would be greatly appreciated. It's a 1998 Yamaha S115TLRX.
Compression is between 128 and 135 on all 4 cylinders.
