Hi folks, 1999 Johnson 175 Hp bogging down (randomly) when trying to get on plane….no rhyme or reason when it occurs say during a 4 hour fishing trip…sometimes it happens after navigating the no wake zone and the first attempt to get on plane, sometimes it happens once out in the ocean several hours into a trip- but always happens maybe after 10 minutes of trolling speed or no wake zone speed
The solution has been to turn off the engine, trim it all the way up, lower it back down then she takes right off…I initially thought it would be a stuck carb float/needle.seat issue but rebuilt all 6 carbs with oem kits and still happens….then I remembered the vst also has a float in it- could that float be getting hung up? Just seems like there could only be so many potential problems if the solution is just to trim the engine all the way up then I’m good to go
Any ideas/input greatly appreciated!
