billgiles2
I have a problem with being able to accelerate when I am in forward or reverse. Works fine in neutral. I disconnected he accelerator cable at the motor end, and the motor accelerates fine in Forward, Neutral, and Reverse. I took the control box apart and didn't see any worn parts inside, so I greased the whole inside with Johnson Triple Guard Grease. No help. I don't suspect the cables because it moves freely in neutral. I wish the control box was made out of clear plastic because then I could see what was going on. Am I doing something wrong, or has anyone else had this problem? I would appreciate any help you could give me. I haven't removed the control box cables or wiring because I am afraid I may not get it back together correctly, but if I can't figure out the problem, that is the next step. The boat has been sitting in the Arizona weather for about 4 years, and never started until a couple weeks ago.
