I put my boat in the water on Sunday and took it for the shakedown cruise. She ran pretty good. As I said before this is my first boat with an out drive. When I shift from neutral to reverse the out drive is slow to go into reverse and I can hear the clutch dog chatter before it goes into reverse. I have to move the shift lever back a few inches much farther than I do to shift from neutral forward. Is there a separate adjustment for forward and reverse? If I adjust the reverse will it also effect the forward adjustment? The forward engagement works fine. Where do I make the adjustment at? Is it back by the engine? Do it up by the shifter/throttle? Thanks in advance.
