Ok first post here, so go easy on me.... haha
I've got a 1983 90hp Johnson V-4 J90TLCTE that seems to be doing the lean sneeze (or that's what I think its called)... big surprise right...
Back story on when it started, coming back from the 4th of July fireworks, it was dark and low tide in an area that I wasn't familiar with.... guess what I hit? Yup a ledge with the lower unit, cracking the housing, wrecking the prop, and bending the shaft... 'twas a super fun evening... made it back to the dock at just over an idle. It would cough and jump every 1 to 5 min, sometimes 4 or 5 times back to back, but it never stalled and made it back to the trailer.
Next morning i go out to look at it and I see what looks like burnt oil running down the sides of the housing. I originally thought this was simply from being just above Idle for almost 3 hrs. Plus I see all the damage to the lower...
Come forward to this past weekend.... I swapped out the lower unit, put on a new prop, cleaned the carbs, replaced the enrichener thingy, new plugs, new wires, checked compression (125 to 132 across the board), replaced a couple fuel lines that were leaking.
I put it in some water and fire it up.... and guess what, still coughing and sneezing.... It does it at idle, at high idle, and it stalls under load...
I have a nice blue spark on all 4 plugs when out in the open.
Left cylinders seem to get hotter than the 2 on the right.
The reeds don't seem to be blowing back trough the carbs.
Gonna buy another set of plugs and try to clean the coil mounts next.
If that doesn't help thinking it could be keyway on the flywheel? or the crankcase is leaking (tho I don't see any new oil since that night)?
Any other ideas?
-James
Any other ideas?
-James
