You guys are always helpful (and often brutally honest) and it's helped me learn alot. Here is another 18 powerhead. I picked this up at the AOMCI swap meet a few weeks back and just got around to checking it out. I bought the full motor as a parts motor, very cheap, and really only expecting to get lower unit castings out of it. But I cracked open the powerhead and found some promising things.
1. Compression check before I popped off the head showed 135 on top, and 130 on bottom. This is the highest compression I've found, and this is my 3rd candidate powerhead.
2. Rings all pass the spring test, no visible corrosion anywhere inside the combustion chamber or crank case (only opened the bypass covers)
3. Exhaust side had the least carbon buildup of any I've seen yet, not sure if this means anything, but it was nice to see, less cleaning if this becomes a candidate.
4. Piston skirts are cleaner than any I've seen yet.
5. Cylinder walls look good to my untrained eye.
So some pictures:
Bypass covers.
So some pictures:
Bypass covers.
