I hope you are just kidding. I don't know everything, but in my books a TDC mark is a TDC mark. And 6ºBTDC is 6º Before Top Dead Center. And as far as I can recall I have never participated in a discussion in this forum (and I have participated in a few) about the timing marks being off 10º on any OHC AQ 4 cylinder engine. Have I missed something during all these years?I agree. Although I wonder why my damper pulley does not line up as everyone indicates it should. I know that the gear behind the pulley is lined up at 0 so maybe the pulley does indicate 10 degrees and that would be why when the ignition timing is being set you retard the dist to get 6 degrees with the timing light? I might not be as dumb as I thought!![]()
Check again when the boat is in the water. If the vibration is still there, then it will be time to think about its origin.good thing is it has life. Can you point out what might cause the vibration in the engine on and off? I know it shakes the drive then smooths out, then goes and does it again.
Thats what I say with the lines and marks all lined up correct set the timing at 16 dbtdc should be 6 degrees with the volvo penta damper pully. Adjust the idle air out as far as necessary for a smooth idle at 900 rpm. Once again set the idle air out for max rpm and adjust the idle speed with the stop screw. Make that adjustment with the control cable off so it dont interfere with the travel of the butterfly, Then adjust the throttle cable so the spring has slight pressure on the throttle lever pushing it closed to the stop. Get it on the water you have put it off long enough. I suppose you could just put a mark on the damper pully when you have the marks all lined up put the damper on and mark it at TDC and use that make for timing purposes. Check the total advance also take it to 4200 rpm the timing should be between 32 and 36 DBTDC. If it runs good go kill some fish.
