So I have a Johnson 200 hp J200vxsss, while I had the lower unit off for water pump replacement I decided I probably should change the drive shaft bearing seal, when I removed the bearing housing I noticed the bearing housing shim was worn through and needs to be replaced, problem is the exploded view shows two shims, and the parts list lists 3 shims .003,.004,.005 witch one or two do in need, please help
