Brian silk
Happy New Year. Still waiting for my haulout to investigate my rough starts. Another issue I want to check out. My dash voltmeter started to read low so I turned on the voltage data field display on both my chartplotters. The voltage they both show is between 14.4 up to 14.9 v depending on revs. It seems way to high on the top end. The temp here is around 0 degrees C or 32F. I know the alternator is temperature regulated, but should it be this high? I have tested the two batteries with an electronic resistence tool and they both test right on spec for cold cranking amps. they hold a charge, and don't seem to be boiling of fluid.
