Pulled my boat for Hurricane Florence. It was ready for a 100-hour maintenance anyway. As an experiment, I pulled the T-stats and hooked up the flushing hose. Contrary to what I have been told and believed, flushing water does eventually get to the T-stat openings. It takes a couple of minutes to get there, and there is no pressure at all on it. It just sort of oozes up there. That's with the T-stats removed.
HOWEVER, if the T-stats are still in place, as in normal flushing, an air pocket will form under the T-stat and that will prevent flushing water from getting there, thus all the corrosion problems in the area for saltwater boaters.
After I buttoned up everything, I got to thinking about how to fix that issue. (Yes, I'm a bit slow at times!) Seems like if you drilled a 1/8" hole in the top skirt of the T-stat, that would allow air to escape and allow flushing water to get to the seating area. A hole that small is not likely to affect the operation of the T-stat.
Next time I pull the boat, will likely try that and see how it works.
Criticisms and comments are welcome.
