Nasty Wendy
So I'm doing so long needed maintenance on my engines while I have the boat home because of non-engine work I had to do to it. All the typical stuff plus I pulled the injectors to have them cleaned. The starboard engine had definite miss at low rpm. I cleaned and changed all the filters and screens (yes ALL those hidden ones too). The one at the FPR wasn't dirty. It wasn't pristine but nothing to inhibit fuel flow was there. I changed the FPRs on both engines as well as new NGK plugs (I have a set of autolites that are listed as a direct replacement for the NGKs but I haven't had the courage or need to try them). The professional cleaning of the injectors, new plugs, and the new FPRs have my engine purring like a single kitten (port engine) and a sick kitten (starboard engine). I changed the FPRs because my fuel pressure was a wee bit low on my starboard engine (changing them both allows me to keep one to have as a test part should I need it) and my pumps are nearly new and pumping strong. New regulator did get me back in the specified range (I was at 37psi and now I'm at 45 psi). The starboard engine's misfire was still present and even easier to pinpoint with the other 5 cylinders dancing perfectly. So I popped on a new ignition module even though the original one tested good (I keep extra stuff for this type of thing) and it made no change. I moved sparkplugs around but the misfire remained on cylinder 6 (bottom cylinder on my left). I chased vacuum leaks even though there weren't any. I fixed the IAB to get it moving freely again and I know that needed to be done but it didn't fix the misfire. So I pulled the injector and checked it. I ohm'd it and it checked out 11.5Ω, perfect. I clicked it open with a 9v battery and sprayed brake parts cleaner through it and it worked. I put it back in puzzled. Fired up the engine and the misfire was still present. So now I'm talking to all my car buddies and they all are stumped. It has fuel, air, and spark but won't fire. Today I decide I'm going to move the fuel injector to a different cylinder and the freaking misfire moved with it. I'll have another injector here soon but I'm puzzled as to how a fuel injector can pass all the tests and still not be good. The misfire moved with this injector and the previous non firing cylinder is now firing. So after reading this book I wrote I'm asking ya'll to respond with theories, experience, knowledge, or guesses as to how an injector can pass every test but not pass fuel into the cylinder.
