I have a long history with this issue.
This past winter engine overhaul, all water passages cleaned and checked. New fuel injectors (not that I had fuel issue), new water pump (3rd one), new thermostats, checked resistances on temp sensors. This time I installed external Oil Cooler and also external high pressure water pump injecting fresh water into top exhaust service ports on manifold. Also ported the 2 water tubes on top of exhaust manifold directly out of the engine.
Put boat in water 2 days ago. today took it for a ride. Without the High-pressure water pump on, it took a bit of time once on plane to throw Overheat alarm. Then I turned on the water pump and that extended the period some more, but soon after the alarm once again. With the water pump I installed a solenoid on the lower service port and having the pump on the top service port. Therefore, both service ports getting cool water. With everything operational the engine did not throw any overheating alarms.
Anyone have any idea why this engine is running HOT?
