ISSUE: Port engine loses RPM, the old owner complained there was something wrong with the port engine.
BACKGROUND
I have twin BF200 A2 with twin external RACOR. The engines have less than 900 hrs on them. The old owner deferred maintenance which I'm correcting. I have replaced the RACOR's, low pressure fuel filters (the old owner ran without low pressure filters) and the HP filters by the VST. The port HP filter contained some gunk, not a lot but some. I drained the VST and the gas looked clear and bright, no debris.
I poured Sea Foam in the gas tank. I have not pulled the tops of the gas tanks for a visual.
My initial run both engines hit about 5250 RPM. About an hour later the port engine dropped about 750 RPM then dropped to about 4000. I started and stopped the engines several times between runs. On one restart the port engine operated great and ran about 5000 RPM's but would occasionally the RPM's would drop.
When I pull back from full throttle to neutral the port engine usually dies.
I am not getting any codes. I have the computer with HealTech software and the system isn't throwing any codes.
NEXT STEPS
I have a fuel pressure gauge. Should I check to see if I am getting full pressure (around 41 psi if I remember from the forums) or just move ahead, check the screen on the fuel pump, check the fuel rail, and check the fuel tank pickup?
BACKGROUND
NEXT STEPS
