ISSUE: How long does it take for the overboard discharge to start working?
BACKGROUND
I just bought a used 1990 S2 Pursuit 265 with twin 2002 Honda BF200A2 with under 900 hours. When I looked at buying the boat both engines started. The boat was in dry storage and we had to use earmuffs to run the engines. The stbd engine had a good overboard discharge and the port no discharge. We did run the engine long enough to check for codes (only the O2 sensor and a low throttle voltage I think) and ahead and astern propulsion. The no discharge issue was a crimped hose to the overboard connector.
THERMOSTATS
Since then I started tearing into the engines since it had been sitting for a year to get a handle on how she had been treated. I found a number of issues but I found all 4 thermostats missing and corrosion where the thermostat sits, I had to scrape it to get the new thermostats to fit, not much but some. I did a test run on the stbd engine with the earmuffs and there is no overboard discharge (no pee stream), I don't run it longer than a minute to avoid overheating and I did it a couple of times but no overboard. The water does come out of the prop but not the overboard. I also took the hose off the thermostat housing and there was no flow there either.
I did get overboard discharge when I put the hose into the thermostat hole in the block. The yard owner says he has low water pressure and the block may not be filling with water. I haven't put it in the water yet since I'm waiting on fuel filter parts and a new thermostat housing for the port engine.
My question for the board is does this sound right? Why would it work without thermostats but not with thermostats? Did I just not wait long enough?
Thanks in advance and I look forward to your learned response.
ps, I'll post my other issues separately to avoid a long rambling post.
BACKGROUND
THERMOSTATS
