Congratulations! Looks like y
Congratulations! Looks like you are doing good...
Hope you cleaned any debris out your oil pickup screen before you put it back in.
Try to keep you motor tilted up enough so that the exhaust reliefs (The two ports in the mid rear of the engine that go through you plastic lower covers are several inches out of the water.
You can also check your bottom port spark plug after you run it a few times and check for water.
That water is probably related to the water injestion but may be something else.
