Hi
this afternoon I was cruising at 4000rpm on my Lund Baron 2003 and his BF225 also from 2003 with 400 hours on it
I needed to come to a stop and slow down progressively and put the boat in neutral without switching it off.
once I put the control forward the boat rev up but in neutral. I was never able to put this boat in neutral and rev it up before.
then when I put the control to the neutral position, the boat would go backward since the reverse was now engaged
Shut down the engine with the key but when I re started, the engine started with the reverse engaged
impossible to make it go in forward so I came back home on my kicker engine
I have removed the cowling and the cable seem well connected and seems to have full range of motion. It also move the lever under the cowling (don’t know the name of that part)
Could the problem be in the lower unit ?
