My motor is a BF30A LHSA pre-1997 with over 3000 hours on it. The telltale usually runs very strong, but recently, it is running quite weak. I will add that the transition from strong to weak was very sudden. At the beginning of a fishing trip it was strong, and at the end, it was weak. I have already checked the hose that runs from the bottom of the water jacket cover to the telltale exit, and it is not blocked. I also checked the lower unit, and there are no blockages between the water intake and the beginning of the water pump. Also the impeller is in perfect shape. I'm sure I am overlooking something, hopefully you all can point me in the right direction. Could I have a blockage somewhere in the water pump inside the motor? If so, how could I remove it?
Here are some recent fixes/problems I have done/am having, maybe they will shed light on the matter?
- Carburetors need to be rebuilt
- Choke does not work unless the throttle is very open
- Lower unit oil seals were compromised and replaced (water mixing with gear case oil)
- I recently slightly lowered the extension case from the motor to replace a gasket, could I have damaged the water pump in doing so?
- Replaced all impeller water pump parts in the lower unit
- Replaced timing belt
Thanks in advance for your help!
