I have an early 00s Honda BF50D outboard running on a pontoon that is used multiple times a day throughout the spring, summer, and fall. Yesterday, while doing a regular run across the lake to pickup supplies, the motor unexpectedly cutout and would not start again.
When troubleshooting both immediately after and later in the day when it had completely cooled, the engine would either crank and shudder, or start and run for a couple of seconds (shuddering and coughing) before dying again.
What I have tried so far:
I have ensured that the engine is recieving CLEAN fuel (took apart all filters and pumped gas through all lines to rule out blockages/water in the lines). Battery is good, and I ensured all fuses were installed correctly and not burned out. Replaced the spark plugs even though I had just replaced them this spring. Noticed an oily substance and a higher than usual amount of soot in the spark plug block mounts. Cleaned the air filter. Prior to replacing spark plugs, engine had only started once during troubleshooting. It started and ran (again, roughly and only for a couple of seconds) 3/7 times I tried after I replaced the spark plugs.
My question is this:
I live very far away from a dealer, and since this motor is semi permanently attached to a rather large pontoon, I'd rather not have to tow it anywhere. Is there anything else I should try? Any last resorts? I have plenty of tools and experience working on land vehicle engines. Any help is greatly appreciated!
