I have a BF50 D (S#BBEJ1012938) that dies after running approx. 45 min. Put a high pressure gauge & diagnostic equipment that determined that the fuel pressure was dropping off when the engine died. (no alarms). The HP fuel pump & EMC are new. When I attempted to start the motor, I can hear the pump run for 2 sec. I installed a low pressue gauge @ the outlet of the LP pump, reading 1/2 to 1 1/2 psi. I cannot find what the pressure should be in my factory manual. This seems low, does anyone know what the pressure should be? If I reved the motor up it did not change much. I ordered a new pump (16700-zz5-003) & installed it. the pressure is not much better. (this is with a shop tank connected directly to the LP pump). While on a river test, the pressure will slowly climb to 3psi at different rpm runs. the motor did not die but IMO, the pressure is too low. The LP pump & push rod are non adjustable. Your thoughts.
Iceman
Iceman
