BF75A Obstruction in Cooling System?
Dtersch
Hi All,
I have a 1998 Honda BF75a and it overheated the other day after a long fast run.
I found some debris blocking the port leading to the tell tale, but nothing too crazy.
Replaced thermostat, still overheats right away and looks like good flow out the prop / tell tale.
Remove the thermostat, no overheating, and looks like good flow out the prop / tell tale.
So I guess I have some flow reducing obstruction somewhere below the bypass valve on the way down n out.
Anyone have an idea to get this cleared? I tried vacuum and flushing with hose, but can't seem to get it.
PS boat is in the water and I do not have a trailer, so all work shall be done in the water. FUN!
Thanks all. I got some videos too. If anyone ever ran their honda w/o thermostat - what happened in the end? lol
Hi Dterch,
I would advise testing or replacing the tstat before assuming a blockage is causing the problem. It could be as simple as the stat is stuck closed.
A pot of water heated on the stove is all you would need in order to determine if the stat opens or is stuck closed.
If you have a thermometer you can place in the pot, that would be a help in that you would minimize the amount of time spent heating the water and make the test accurate.
I don't have the specifications or service information for that outboard but I would guess that the stat should be fully open at 140° to 160° degrees Fahrenheit. Again, that's a guess on my part.
If the water temp gets higher than 160° to 180° with no opening of the stat, I would definitely replace it and then try running the outboard again.
Good luck and let us know what you find.
Thanks sir! I tried the pot of water method and found both old and new opened at right temp. So the thermostat doesn’t seem to be my issue . I suspect a piece of old impeller from a previous owner or something else maybe obstructing the water flow.
The interesting thing is, I ran this motor for maybe 20 hours at least before the problem developed. As it is a 1998 motor I’m sure it has many hours on it.
Yes, probably many hours and mineral buildup too. Especially if it did most of it's work in salt water.
I don't want to be the bearer of bad tidings but you may be in for some unpleasant disassembly to look for that blockage. A task that you will  not want to be doing while in or over the water.
You may want to try a vinegar flush in a trashcan prior to any disassembly to help dissolve and break up any internal deposits.
This issue may require that you remove the gearcase with pump and try pushing whatever might be in there out the bottom by backflushing through the thermostat housing with as much pressure as you can produce. . Creating a seal with a rag helps to contain and direct water or air pressure for increasing velocity
If it is a piece of impeller, there's a chance it might come out that way. You'll want to be where anything that does come out, you'll be able to see what it is.
If nothing comes out, you might need to go into the water jacket or even remove the cylinder head to find the issue.
With I had better news.
Good luck.
No, there isn't.
Trying to flush the cooling system through the exhaust system would probably end up with flush water entering one or more cylinders and, ultimately, going into the crankcase. Not something you would want to happen.
Exhaust gasses exit the cylinder head via a single pipe (see item 11 in link) and get dumped into the space inside the extension case for cooling and sound dampening before exiting the prop hub.
Good luck.
So i tried a thermostat set for 140F instead of the 160F standard one. Still overheats. I see good flow out the prop exhaust port, but wonder if I am losing too much thru the bypass valve. I pulled the spring out a bit. still seems only way I can get enough flow thru the engine is just to fully remove the thermostat.... running out of ideas. Thanks JGMO for the conversation!
Any suggestions welcome. I have a video I may try and upload as well.
I've already said my piece.
While I'm no guru for this outboard...
...never worked on a 75hp...
...just pointing out that the tell-tale bypass is the FIRST passage that gets water after leaving the pump.
A good pee stream really means NOTHING to cooling other than to indicate the pump is, indeed, moving water as expected.
As a matter of fact, the pee stream will get a bit STRONGER if there's a blockage down stream from it in the system. As a result, you should take no great comfort in the excellent tell-tale volume for what's happening with your outboard in this case. Sorry.
Good luck.
Update- took apart the whole cooling system. found two bits of old impeller and the 'new one' the guy put on. guess what
? no woodruff key at all! shaft can freewheel almost inside the impeller. so, new parts on the way. I think this was the smoking gun though!
Well....good!
Now, you have to ask yourself "did the guy put a drive key in there and if so, where is it now?"
Not sure I would be comfy with a hard chunk of metal bouncing around in there. Hopefully you found it or he admitted he never installed it.
Those keys can fall out easily too if the slot in the mainshaft is worn so make sure you check that closely.
Hoping the repairs go smoothly from here for you.
That's the shift shaft. I believe it's indexed with a slot that's wider than the others but I'm not positive about that without looking it up because I've never worked on a 75hp Honda and I don't have the service manual.
If it IS indexed, you just need to match the position with the shaft index (wide spline) above it.
As to where that pump drive key wound up,.it probably fell DOWN next to the mainshaft. You might find it by fishing in there with a pencil or small flex magnet.
Good luck.
jgmo you're a genius, sir. thanks. so i shook the gearcase upside down and out came the woodruff key.
Guess now is that I caught a bag (likely in the filthy water i was ripping thru) and i guess impeller ran dry and failure mode was inner housing wearing and woodruff leaving the chat? ill update once she's all back together - could be a few days. waiting on parts is the wooorst!
Cool! Glad you're making progress.
The wait sucks but the pain vanishes when they show up and are what you needed.
Waiting to hear how great she runs when you get it buttoned up.
Mission failed. New impeller also didnt solve anything. I suspect now a blown head gasket or something worse. Engine will barely start or run. No longer seems cooling system related. the chase goes on, or I am done with this motor.
Sorry, just seen it's the older 75. Think you will find silt build up around number four cylinder, seen a few like this, head off will reveal.
Oddly had a successful seatrial yesterday. No overheating, seemed to run as it should. Thinking to replace the temp switch with a sending unit to view the temp real time.
Well...that seems very odd but...
...definitely encouraging.
I'm always suspicous though when a machine "fixes itself". It's likely to only be temporary.
I don't know the particulars about if your early model has engine protection built in or if it goes into "limp home" or not but you don't want to defeat that system making changes.
I assume that you mean you want to install a temperature gauge. Not a bad idea but not at the expense of engine power de-rate for overheat.
You would be best served if you could do that by leaving the temp switch in place and installing a gauge sender "in parallel" so that you get the information you want but still have engine protection functional.
It could be as simple as installing a "T" fitting to accept both sender and switch but I don't know.
I hope you can get this figured out.
