Is there such a thing as a double breaker that has a separate DC and AC line passing through it?
I need a 12v (25 amp) line and a 220v (15 amp) line that if one is tripped the flow on both lines will stop.
I’m using it for a 220v (15 amp) marine air conditioner that requires a 12v (25 amp) water cooling pump running at all times the air conditioner is running. I want one breaker switch that turns them both on/off together and will trip if something goes wrong on either line.
The purpose of both being on the same breaker is so one can’t run without the other - one switch controls power to both.
I would appreciate the correct name/model number of what I have described above (or a more suitable suggestion if better).
