boardhauler
I have a 2006 Mercury 30HP EFI. It starts and runs perfect, until I shut it down when hot. Then it will not start and run in idle. The hotter it gets the worse it is, until it will not start.
I ran it in the yard and the same thing. It starts and runs perfect, then about 2 minutes later, dies. I can restart it, but it will not idle.
The Rinda Tech shows that the throttle is at 13% when I can see that it is closed/shut.
I removed the IAC tube to see if that made a difference, it does not.
