Progator135
1985 E50BELCO
I just rebuilt it and even before that I was having idle issues. It is spitting fuel from the Idle Bleed Orifices (Not from carb Throat at all) and I have to crack the carbs ever so slightly with cam adjustment to get to stay Idling. If I adjust it back and close them completely it dies out unless the timing advance is completely maxed out - Wrong on every level.
Things I have done/checked:
1. Got new(used) carbs that have much less slop in the butterfly shafts; (Thanks scalhoun) rebuilt with all new gaskets & parts, pulled core plugs and ran wire through idle ports - all is clean and new and as perfect as can be. Float level was set where the non-hinged end was maybe 1/64" higher than level. Needle valve was sealing good when Id blow in intake and flip carb upside down.
2. Compression test - Both about 149.
3. Reed valves pulled cleaned checked - I had about 8-10 psi difference in the cylinders compression at first - thought that may be the culprit. Actually took my old reed valves (the block I bought came with reed valves - they looked fine so I used them) and did a thorough cleaning and inspection and they are in perfect shape. all flat and sealing good. Changed them out and reinstalled with a new gasket from rebuild kit that I didnt use during rebuild. This evened out my compression thankfully but no help on idle.
4. Spark test - both jumping 7/16 gap like a champ.(with new storebought tester) No issue there. Also did cylinder drop test and motor reacted as expected on each cylinder test.
5. Checked fuel lines/hoses. All new, clamped or zip tied tight. No leaks or air being drawn in. Even little tubes from primer are new.
Question: Turned over motor with fuel line from pump disconnected to check fuel delivery - how much should be shooting from pump while turning over - I had a decent trickle but It wasnt shooting across the yard either - whats the norm for this? I rebuilt the fuel pump last year but who knows. (I remember the new circular snap in valves were much stiffer than the old ones, I had some concern with this when I rebuilt it)
6. Squeezed primer bulb while running/stumbling/coughing/spitting - no change at all...
7. Pulled flywheel and made sure it was on correctly and hadnt slipped the key. All is good.
8. Checked all wiring and plug leads for any stray voltage shorting to ground or any other abnormality. All is good as far as I can tell.
9. Brand new plugs gapped to .030
Well thats my story...any Ideas? Im gettin fed up.
