Hey J/E Forum,
It's my first time taking apart my carbs and cleaning them and some info would be of great use. I currently have a 1997 Johnson/Evinrude 200hp Oceanrunner J200TXEUA and the reason for the disassembly stems from throttle issues while I was out on the water. During the disassembly and cleaning process, I noticed one of the screws (circled in yellow on the image) is missing on the right carburetor. Does the right carburetor need one as well? I also uploaded an image of the screws that belong in that spot. Also, I used carbueretor cleaner and compressed air during the cleaning process. I will allow them to air dry as well as i wait for the new parts to come in. The carburetor cleaner is quite sticky after using compressed air. Do you guys recommend to wipe them down with a clean towel?
As for the throttle plate, what cleaner do you guys recommend i use?
Thanks again
Thanks again
